Jeff-Dalton
Feb 08, 2021Tutor
Nighthawk MR60 satellite issue connecting after brown out
I have owned the Nighthawk MR60 mesh system for about 10 months. My system has two satellites which worked perfectly for extending the range of my WiFi in my Large footprint home. The system worked...
wtfareprntlcntr
Feb 09, 2021Guide
i don't think it's the brown out. It most likely updated firmware when it rebooted.
I had the same problem. Internet kept turning off and rebooting. I was able to solve it with customer support but thought i'd document it and post it here. There should be an attachment that is poorly put together but will give you the basic steps. It's so frustrating that the satellites don't update with the router.
I've also set my router to not do automatic updates which mean i'll have to remember to go in and look for them.
