ikdutak
May 28, 2024Aspirant
Nighthawk MR60 Satellite Ping spikes when gaming
Hello. I have an MR60 Nighthawk Mesh setup in my house. I have the main router hooked up in my office, and my gaming PC across the house. The PC requires Ethernet, so I opted to place one of the sate...
michaelkenward
May 28, 2024Guru - Experienced User
Reference to "the main router" suggests that there may be another one somewhere on the network. Is there?
Also, what modem/gateway/ONT sits between the router and the Internet?
Then there is the firmware version on the MR6Xs. A number please. Claims of "the latest" can be hopelessly wrong, thanks to the way Netgear's technology works.
The PC requires Ethernet, so I opted to place one of the satellites on my desk there, and hook a switch to the satellite, so both my PC, my wife's PC, and my work PC can all connect via ethernet.
Is the MS60 wired to the MR60?
- ikdutakMay 28, 2024Aspirant
Apologies, my wording might have came across oddly. I referred to the MR60 as the Main router, as it's the point that plugs into the modem (Spectrum D3.1 eMTA DOCSIS 3.1 Advanced Voice Modem, couldn't find a model number). The firmware is 1.1.7.134_2.0.65 on both the MR60 and both satellites. The satellite is connected wirelessly to the hub, which I assume is where the problem lies. Are you able to connect them via ethernet for better stability?
- michaelkenwardMay 28, 2024Guru - Experienced User
Yes. "Wired backhaul" is a better option, if it doesn't mean digging a trench through the middle of the house or tearing down walls.
I use Powerline Ethernet but that doesn't suit everyone. I am stuck with VDSL Internet.
You have the newest firmware. So no problems on that front.
I may be able to run an ethernet backhaul cable. I already have a hole drilled down into the crawlspace for one cable, cant hurt to put another down there!
