AlGear's avatar
AlGear
Guide
Dec 12, 2021
Nighthawk MR60 satellites won't stay connected
Greetings, I bought a Nighthawk Mesh WiFi 6 Router (MR60) last July, and it has been working great, up until a week ago. Now, the two satelittes won't stay connected. Their lights turn amber, and whi...
  • FURRYe38's avatar
    To be sure, just connect a ethernet cable to the back of the MS unit and the other end of the cable connected to the Mac ethernet port. Turn OFF the wifi radio on the Mac. Press the reset button in back of the MS for 10 seconds then release. Give about 5 minutes and check the Mac Networking configuration to see if a IP address appears on the Mac. If so, try accessing 192.168.1.250 on the MS...
