TLP560
Jan 03, 2023Aspirant
Nighthawk MR60 Setup
hi all, I used to have a google wifi ac1200, and recently just upgraded to this MR60 (was told it'll be faster 🙂 setting up was a breeze with 2 satellites, and i used the exact same setup with my...
- Jan 03, 2023
You can try optimizing placement of the satellites. hardwire a laptop into them and test their speeds in different locations.
You can also try using different wireless channels. Sometimes theres interference on some. So swap the 2.4ghz and 5ghz channels around a little to see which is faster for your area.
Jan 03, 2023Guru - Experienced User
What wired speed do you get?
What speed do you get if you're connected to the router and not a satellite?
What speed do you get over 2.4ghz? And 5ghz?
