MicroNaught
Jun 24, 2024Aspirant
Nighthawk MR60 Slow Internet Connection
Howdy all! I have the oddest of problems with my MR60 mesh network. On the initial setup of the router I used the app and the router connected at 1gbps as it should. I cannot remember why a reset...
MicroNaught
Aug 06, 2024Aspirant
I usually run it in AP mode but it still 30mbps for all wireless devices. The devices are somewhat frequency separated between 2.4GHz and 5GHz. I can actually run speed tests on all the devices at the same time and they all get 30mbps results.
The main reason for wireless around my house is streaming entertainment and all my streaming devices work just fine all at the same time. This problem has simply baffled the s**t out of me.
8 port Netgear ProSAFE GS108E smart switch.
Also, we do not have a modem. We get an Ethernet cable from the fiber optic CPE into the house (FttH). Plugging this cable directly into the MR60 router doesn't affect the connection of 30mbps. I've tried this several times. I even factory reset the router before plugging the cable into the Internet port and there is no change. This a MK62-100NAS (AX1800) Mesh WiFi 6 system with 1 router (MR60) and 1 satellite (MS60). Plugging the Ethernet cable into the router is bypassing both the switch and firewall. It is a direct unfiltered Internet connection.
MicroNaught
It works good enough and I should let it be. I hoped it was a setting I was missing somewhere in the advanced configuration section.
I wanted to have a better wireless link between the router and satellite since my NAS is on the satellite side. I guess it's cat 6a cable time.
