Gatesway
Dec 28, 2020Aspirant
Nighthawk MR60 Slow wifi internet speed on Mac
When running speed test, at modem I have 100 down, 20 up. Using the MR60 on WiFi (I'm sitting next to router running V1.0.6.102) it is rare to even get 20 down - usually 15-16. I've made sure the f...
Dec 28, 2020Guru - Experienced User
what modem/gateway are you using?
Also, are you connected to the 2.4ghz or 5ghz?
what speeds do you get hardwired into the MR60?
Gatesway
It is an AT&T modem (UVerse) BGW210-700.
I'm connected to 2.4ghz. DOn't know how to change to 5ghz.
Have not connected "hard-wired" to the MR60. Did not think I needed to.
Thanks for any help!
