Gatesway
Dec 28, 2020Aspirant
Nighthawk MR60 Slow wifi internet speed on Mac
When running speed test, at modem I have 100 down, 20 up. Using the MR60 on WiFi (I'm sitting next to router running V1.0.6.102) it is rare to even get 20 down - usually 15-16. I've made sure the f...
Gatesway
It is an AT&T modem (UVerse) BGW210-700.
I'm connected to 2.4ghz. DOn't know how to change to 5ghz.
Have not connected "hard-wired" to the MR60. Did not think I needed to.
Thanks for any help!
Dec 28, 2020Guru - Experienced User
Gatesway wrote:It is an AT&T modem (UVerse) BGW210-700.---which has its own integrated router and can cause issues with double nat.
https://kb.netgear.com/30186/What-is-Double-NAT
I'm connected to 2.4ghz. DOn't know how to change to 5ghz.----it should bandsteer to 5ghz as needed. but if its on 2.4ghz, yours speeds will be slow. 2.4ghz is a slow network and sensitive to interference.
Have not connected "hard-wired" to the MR60. Did not think I needed to.----You don't need to but for testing, its a good way to ensure the router is getting full speeds.
