Gatesway
Dec 28, 2020Aspirant
Nighthawk MR60 Slow wifi internet speed on Mac
When running speed test, at modem I have 100 down, 20 up. Using the MR60 on WiFi (I'm sitting next to router running V1.0.6.102) it is rare to even get 20 down - usually 15-16. I've made sure the f...
Dec 28, 2020Guru - Experienced User
Gatesway wrote:It is an AT&T modem (UVerse) BGW210-700.---which has its own integrated router and can cause issues with double nat.
https://kb.netgear.com/30186/What-is-Double-NAT
I'm connected to 2.4ghz. DOn't know how to change to 5ghz.----it should bandsteer to 5ghz as needed. but if its on 2.4ghz, yours speeds will be slow. 2.4ghz is a slow network and sensitive to interference.
Have not connected "hard-wired" to the MR60. Did not think I needed to.----You don't need to but for testing, its a good way to ensure the router is getting full speeds.
Thanks for any help!
Gatesway
Dec 29, 2020Aspirant
Thanks for the reply!
First off, I have the WiFi disabled in the AT&T modem/router as it was causing problems.
Not sure how to change from 2.4 to 5ghz - but I'd love someone to help with that.
Lastly, now the Nighthawk app says there is no WiFi. There is. I'm using it right now. Both satellites are working. The app can't even see the router let alone the satellites.
HELP!!!
Thanks,
JG
- GateswayDec 29, 2020Aspirant
Good morning.
First off, the AT&T modem says the connection is up and running fine. I have connectivity with the internet. The MR60 has a blue light (says it is connected and producing wifi). I can see the wifi and use it on my Mac. The NightHawk app says there is no wifi detected. But, the phone is on wifi and is connected to the web.
THis AM, I shut down the modem & router and did a restart according to the manual. Started the modem, waited 2 mins. Then plugged in the router, waited till the light was amber. Then tried the Nighthawk app to log in. No wifi detected. But, the phone is!
So weird.
Lastly, the back bedroom satellite keeps losing its connection. It is hardwired to the MR60. Should I take off the hardwiring? It is about 60' away and has 4 walls of plaster & lath between them.
Thanks!
Update.
The Nighthawk app would not detect the wifi, but then I but when I clicked on the "Anywhere access" at the bottom of the "Wifi not detected page", it takes me to the router, shows it is online and that the 2 satellites are not connected.
So, I'll work at getting them connected.
Also, under device manager, all devices are connected to 5ghz except my Apple watch and our alarm panel.
Lastly, I did 3 speed tests:
Nighthawk app: 90 down, 20 up.
speedof.me: 16 down, 10 up.
Smart Home Manager (AT&T app for our modem): Modem: 108 down, 22 up; device (iPhone): 21 down, 18 up.
- plemansDec 29, 2020Guru - Experienced User
Try this. The shutting the wifi off doesnt disable router mode on the att device.
And some struggle to get passthrough modem working properly.
try putting the netgear in access point mode. it disables some functions but leaves the att running the routing
