hsmono
Mar 19, 2023Aspirant
Nighthawk MR60 Wifi 6 Mesh satellite
My main wifi router is okay but my satellite keeps re-booting in this sequence: the light goes off then turns flashing white then solid amber then blue and then turn off again. This sequence repeats....
hsmono
Mar 20, 2023Aspirant
Just to clarify your network, you have the MR60 router and an MS60 satellite? yes, MR60 works fine and MS60's light keeps changing color flashing white, solid amber, blue, then turn off and repeats.
What firmware version do you have on the devices? Firmware Version V1.1.7.134_2.0.65.
The netgear support remoted in on my pc and downloaded the latest version on MR60 and MS60 today 3/20/2023 from netgear website. So the version is whatever version was the latest version this morning CA time. I do not know the exact version.
It might also help if you told people what the modem is in front of this router, if there is one. The make and model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back? My modem is Arris surfboard T25.
Did your conversation with support include resetting the network? I have service plan with netgear support and I reset the satellite but sticking a paper clip in the hole behind the satellite unit for 60 seconds and released. I also synced the router and satellite before that by pushing the sync button on the unit and in the dashboard.
I am not that technical to provide more info.
michaelkenward
Mar 20, 2023Guru - Experienced User
hsmono wrote:
What firmware version do you have on the devices? I do not know. The netgear support remoted in on my pc and downloaded the latest version on MR60 and MS60 today 3/20/2023 from netgear website. So the version is whatever version was the latest version this morning CA time. I do not know the exact version.
Only you, and they, know which firmware is on the device. Without that detail, we are in the dark.
Standard modem, no built-in router to get in the way.
OK. They covered the obvious moves.
If the satellite is simply trying to reconnect to the router, perhaps there is some WiFi interference, or you need to put the satellite nearer to the router.
If the issue is that it keeps rebooting, one thing to look at is the power adapter that feeds the satellite.
If you have a spare lying around with the same output, maybe from some old equipment, you could try that. Or swap the adapters between router and satellite. If the routers start rebooting, that would indicate a power problem.
As you have a support contract (with GearHead?) you could go back to them.
