msekar
Jan 28, 2023Aspirant
Nighthawk MR60/MS60 WiFi 6 Mesh Router 5G Channel Selection.
As the Nighthawk X6 R7900 AC3000 wasn't providing suficient WiFi coverage, I purchased Nighthawk MR60/MS60 WiFi 6 Mesh system with 2 satellites a year ago. I set them up as Access Point behind X6 R79...
- Mar 06, 2023
msekar wrote:
Thanks FURRYe38 michaelkenward as I was able to do a Factory reset of MR60 and set it up ground up as a new system directly working behind the Modem. One of the satellites is connected through ethernet cable and another wirelessly. So far, the system is working fine for 2 days without any issues.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-routerI do have a couple of questions.
I tried to add another Satellite MS60 purchased on eBay (secondary market unit). The adding part was easy - Did a factory reset of MS60, added it using Web interface of the router. The new satellite appears on the system but the network has become unstable; meaning, the other satellites are going offline randomly. So, I removed the new satellite to get the network back into working condition. My questions..
1. Is there some prep I need to do to properly get the newly purchased MS60 in secondary market added to the network? Ensure the FW is updated to same version as what's on MR or current MK system.2. How to delete the newly added MS60 from the network configuration? Turn off the MS and select remove from the MRs web page under connected devices?
Glad you got it working. Please mark your thread as solved so others will know.
Jan 28, 2023Guru - Experienced User
msekar wrote:
As the Nighthawk X6 R7900 AC3000 wasn't providing suficient WiFi coverage, I purchased Nighthawk MR60/MS60 WiFi 6 Mesh system with 2 satellites a year ago. I set them up as Access Point behind X6 R7900 router which was connected to the Comcast Modem. Everything was working great until I decided to simplify the network by removing X6 R7900 between MR60/MS60 Mesh Router and the Comcast modem. After this, my home network became very unreliable. I spent enormous amount of time trying to troubleshoot this issue. Here the deficiencies I found with Nighthawk MR60/MS 60 system which are very basic and could be found in any cheap router.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
1. The DHCP server in MR60/MS60 is very flaky as both wired and wireless devices often fail to get valid IP Address. I say this because X6 R7900 router was acting as DHCP server before and no issues.
I presume you have set the MR back to router mode after you removed the R7900 router from the mix?I recommend setting the DHCP IP address pool range to 192.168.1.100 to .200.
I haven't seen any DHCP issues with mine that has recent FW loaded.
2. There is no Auto selection of 5G Channels in MR60/MS60 router forcing me to pick a channel. I noticed that WiFi routers from neighbors are often changing channels which may conflict with my network. I can see my SSID but can't connect often.
I use channels 1 and 40 all the time and dont' have any problems with my MK63 system. NG doesn't use Auto on 5Ghz and never has on any of there newer generation routers. I've seen this on other mfr routers as well. 5Ghz has always been a default manual channel or pick someting. No Auto is supported on 5Ghz. Been like this for a while now.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between MR and MS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/000061709/Where-should-I-place-the-Mesh-WiFi-satellite-of-my-Nighthawk-Mesh-WiFi-6-and-Tri-band-Mesh-WiFi-6-products 📡
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
msekar
Jan 29, 2023Aspirant
v1.1.7.134
I believe this is the latest version as indicated by the version check.
Modem is Netgear CM1100
I don't think there is any issue with the modem as it worked with multiple routers before.
Yes, it is a good cable; I tried multiple cables as I have some spare cables.
Yes, I unchecked the Checkbox for Access Point. I also did a factory reset and set it up from scratch.
Will try this later as I am trying it as Access Point (like before) behind the ASUS router.
2400 SFT.
I didn't have any issues with placement of 3 units when I used them as Access Points.
What is the distance between the router and satellite(s)?
They are all within 30 feet distance of each other.
Yes, I tried this without much success.
Right now, I using the ASUS Lyra Trio Mesh router with 3 units as primary network connected to Xfinity Modem with SSID; it is working great with 5G Channel selection set to Auto. I do see 5G channels changing from 149, 157, 161.I setup Netgear MR60/MS60 Mesh router as Access Point with its own unique SSID behind the ASUS router; unfortunately, Netgear is running with fixed 5G Channel of 153 as it doesn't have ability to Auto select. Both of these networks are working good so far. If Netgear addresses these limitations, I will switch Netgear as primary network and remove ASUS router. Otherwise, I have to accept the Netgear limitation and move on.
