msekar
Jan 28, 2023Aspirant
Nighthawk MR60/MS60 WiFi 6 Mesh Router 5G Channel Selection.
As the Nighthawk X6 R7900 AC3000 wasn't providing suficient WiFi coverage, I purchased Nighthawk MR60/MS60 WiFi 6 Mesh system with 2 satellites a year ago. I set them up as Access Point behind X6 R79...
- Mar 06, 2023
msekar wrote:
Thanks FURRYe38 michaelkenward as I was able to do a Factory reset of MR60 and set it up ground up as a new system directly working behind the Modem. One of the satellites is connected through ethernet cable and another wirelessly. So far, the system is working fine for 2 days without any issues.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-routerI do have a couple of questions.
I tried to add another Satellite MS60 purchased on eBay (secondary market unit). The adding part was easy - Did a factory reset of MS60, added it using Web interface of the router. The new satellite appears on the system but the network has become unstable; meaning, the other satellites are going offline randomly. So, I removed the new satellite to get the network back into working condition. My questions..
1. Is there some prep I need to do to properly get the newly purchased MS60 in secondary market added to the network? Ensure the FW is updated to same version as what's on MR or current MK system.2. How to delete the newly added MS60 from the network configuration? Turn off the MS and select remove from the MRs web page under connected devices?
Glad you got it working. Please mark your thread as solved so others will know.
msekar
Mar 05, 2023Aspirant
Thanks
Mar 06, 2023Guru - Experienced User
