doctorjerry
Nov 10, 2023Follower
Nighthawk MR70 LAN supplies two different addresses to attached devices
Nighthawk MR73 Firmware Version V1.0.3.34_2.0.58. My LAN is set to assign ip addresses from 192.168.1.20 to 192.168.1.254. Using DHCP most attached devices are in that range, but some device...
michaelkenward
Nov 11, 2023Guru - Experienced User
doctorjerry wrote:
Using DHCP most attached devices are in that range, but some devices are assigned an address in the range of 192.168.107.xx and thus not able to connect to the internet.
I have been able to bypass the problem by using a fixed ip address for an attached device or a wired connection, but I have never experienced such a problem. Does anyone know why this is happening?
Freaky.
What modem/router/ONT sits between the MR70 and the Internet?
Any pattern to the devices that got the odd address?
Was it just one advice that needed a fixed (or was it reserved) IP address?
