mikey59
Jun 29, 2023Guide
Nighthawk MR70 not showing 5G network?
I've got a MR70 & one satellite, but no 5GHz network showing - how do I enable it? Also, using I'm using the iWiFi app on my iphone to check signal strength, speed, etc., as I prepare to cut the cab...
michaelkenward
Jun 29, 2023Guru - Experienced User
What tells you that it is not showing? By default both 2.4 GHz and 5 GHz have the same SSID (network identifier). You have to prise them apart deliberately. So you won't see either. Just the WiFi.
I'm paying for an 800 Mbps connection & would like to take full advantage of it - any suggestions?
You will never get that speed over WiFi unless you have the latest and greatest, and most expensive, clients. Most kit will be much slower than that.
You are talking about wifi speeds here, so it might be worth a bit of background reading.
Understand Wi-Fi 4/5/6 (802.11 n/ac/ad/ax)
@duckware knows their stuff and can bust a few myths and cut through marketing hype.
