nbeasy
Aug 26, 2022Aspirant
Nighthawk MR80 - admin portal shows empty port forwarding table although there are records populated
I have a Nighthawk MR80 router with firmware V1.1.6.14_3.1.101. The admin portal shows empty port forwarding table although I have populated records and if I try to create something I know already e...
- Aug 26, 2022
Resetting the router solved. Thanks. A pain to reset all the devices and settings, but hopefully not an issue the happens again.
Aug 26, 2022Guru - Experienced User
What browser are you using? Different browser show same thing?
Post a screen capture of what your seeing please.
nbeasy
Attempted with chrome and safari.
- FURRYe38Aug 26, 2022Guru - Experienced User
And this is one a PC monitor and browser zoom factor is at 100%. What happens if you zoom out or reduce zoom factor by 25%? Same thing?
Is this seen across more than one PC?
What OS version are you using?
- nbeasyAug 26, 2022Aspirant
Yea, changing the zoom of the browser or widening it doesnt change. Tried on a few different devices (mac laptop on wifi, mac desktop connected on ethernet, and android using chrome browser in desktop mode) and using both safari and chrome.
