nbeasy's avatar
nbeasy
Nighthawk MR80 - admin portal shows empty port forwarding table although there are records populated
I have a Nighthawk MR80 router with firmware V1.1.6.14_3.1.101. The admin portal shows empty port forwarding table although I have populated records and if I try to create something I know already e...
  • nbeasy's avatar
    nbeasy
    Aug 26, 2022
    Resetting the router solved.  Thanks.  A pain to reset all the devices and settings, but hopefully not an issue the happens again.
