nbeasy
Aug 26, 2022Aspirant
Nighthawk MR80 - admin portal shows empty port forwarding table although there are records populated
I have a Nighthawk MR80 router with firmware V1.1.6.14_3.1.101. The admin portal shows empty port forwarding table although I have populated records and if I try to create something I know already e...
- Aug 26, 2022
Resetting the router solved. Thanks. A pain to reset all the devices and settings, but hopefully not an issue the happens again.
Aug 26, 2022Guru - Experienced User
nbeasy
- FURRYe38Aug 26, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a new back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
