gamesetnmatch60's avatar
May 02, 2022
Nighthawk MR80: DoS attack: NetBiosReply Drop -- fixed
Recently, I noticed several lines in my Router Log that were eventually flooding the Router and causing the LAN connection to drop. The QUICK fix was to disable NetBIOS over TCP/IP in case anyone had this same issue. Attached an image of how to d disable NetBIOS on Windows.
Example of these logs:
[DoS attack: NetBiosReplyDrop] from source 192.168.1.17,port 137 Friday, Apr 29,2022 16:36:41
[DoS attack: NetBiosReplyDrop] from source 192.168.1.17,port 137 Friday, Apr 29,2022 16:35:17
[DoS attack: NetBiosReplyDrop] from source 192.168.1.17,port 137 Friday, Apr 29,2022 16:35:05
[DoS attack: NetBiosReplyDrop] from source 192.168.1.17,port 137 Friday, Apr 29,2022 16:34:54
[DoS attack: NetBiosReplyDrop] from source 192.168.1.17,port 137 Friday, Apr 29,2022 16:34:41
[DoS attack: NetBiosReplyDrop] from source 192.168.1.17,port 137 Friday, Apr 29,2022 16:33:38
[DoS attack: NetBiosReplyDrop] from source 192.168.1.17,port 137 Friday, Apr 29,2022 16:33:17
[DoS attack: NetBiosReplyDrop] from source 192.168.1.17,port 137 Friday, Apr 29,2022 16:33:03
[DoS attack: NetBiosReplyDrop] from source 192.168.1.17,port 137 Friday, Apr 29,2022 16:32:51
[DoS attack: NetBiosReplyDrop] from source 192.168.1.17,port 137 Friday, Apr 29,2022 16:32:41
[DoS attack: NetBiosReplyDrop] from source 192.168.1.17,port 137 Friday, Apr 29,2022 16:31:12
[DoS attack: NetBiosReplyDrop] from source 192.168.1.17,port 137 Friday, Apr 29,2022 16:31:00
1 Reply
