ArieT
Jan 07, 2022Initiate
Nighthawk MS60 in a loop?
Hi, i have installed the MK63 Nighthawk system. The router and 2 satellites are working fine. Due to the structure of our house i recently bought a second hand MS60 satellite for extra coverage....
- Jan 07, 2022
try hardwiring the satellite into the router. That should allow it to connect.
Then the router should assign it an ip address. use the ip address to connect to it and log into it.
From there you should be able to manually update it.
Or you can try factory resetting it and try connecting directly to it.
Hardwire a pc/laptop into it (disable the laptop/pc's wireless).
Its default IP address should be 192.168.1.250 if it hasn't been setup.
Connect to it at that and try to login and update it.
Jan 07, 2022Guru - Experienced User
ArieT
HI, i tried that also but the MS60 was not visible in the connection list. But thanks to your reply i wired it to another satellite en there was the ip. Funny thing was that i had to downgrade the firmware to get it working. But now full speed in every corner. Thanks!
- plemansJan 07, 2022Guru - Experienced User
glad it worked!
