lonestar777
May 25, 2022Aspirant
Nighthawk MS60 Mesh system not working after power outage (can't connect to modem, no nic lights)
Hi everyone, We had a power outage and internet outage last night. Power and internet are back up now, and I confirmed it's working by bypassing my router and connecting a laptop directly to my mod...
May 25, 2022Guru - Experienced User
if you disconnect the router from the modem, then reboot it, and then connect your pc/laptop to the mr60, are you able to access it?
lonestar777
Thanks for the quick response! I tried the below steps and couldn't connect to the router using an ethernet cable. I tried opening a browser and going to 192.168.0.1 and couldn't connect. Please let me know if you have any other ideas!
- plemansMay 25, 2022Guru - Experienced User
did you try 192.168.1.1 (default ip address)?
or 10.0.0.1? (backup ip address if its in a double nat)
- lonestar777May 25, 2022Aspirant
I wasn't sure if the default was 192.168.0.1 or 192.168.1.1, so I had tried both. I also just now tried 10.0.0.1 and couldn't connect either. I don't get any lights on the nic of my laptop or the router.
