BPopilek
Mar 09, 2023Aspirant
Nighthawk MS60 Renaming Not Working
I recently picked up a MR60 router / MS60 satellite bundle on clearance from Walmart for $80 the other day. I figured for the price, it was time to upgrade my old Nighthawk router. Additionally, they...
michaelkenward
Mar 09, 2023Guru - Experienced User
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
It might also help if you told people what the modem is in front of this router, if there is one. The make and model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
I'd have to put my MK63 back on to check however when I got mine last year, I think I was able to change the MS names using the web browser I believe. MS-Edge. I know the NH app should work as well. You do have to make sure that you select the SAVE button to ensure it saves the change. I only changed the last couple of characters on mine, Satellite-DR and Satellite-BM.
- BPopilekMar 09, 2023Aspirant
Every time I have tried to change the name through the app, I have hit save at the end of the attempt. It made no difference. I suppose I could find an Android device and try that version of the app to see if it makes any difference.
- FURRYe38Mar 10, 2023Guru - Experienced User
OK, I put my MK63 online today.
MS had already been re-named and I remembered that I had to use the Nighthawk app to do it.
I used my iPhone 12 Pro Max with iOS 16.2
Both RBS appeared in the app with change from before - BM and DR:
Select each MS and it takes you to the MS display page on the app. Select the pencil icon and edit the name.
After I just added a numberical character to the end of the name for a change, I selected Save on the app and change took place.
Looked at the MRs web page (MS Edge) and also change appeared as well:
NG Genie app is NOT supported on MK series systems. Also that app is EOL!!!
- michaelkenwardMar 11, 2023Guru - Experienced User
