abinda
Mar 26, 2024Tutor
Nighthawk MS60 solid white light
My satellite has suddenly stopped working. It was working fine for a while until now. It will not connect to the router and cannot be reset. The light is constantly solid white when plugged in. Tried ...
- Dec 13, 2025
I could not find any solution, I tried many things, but I ended up having to purchase a new one. I believe this was hardware issue instead of a software one. I'm almost certain the satellite bricked after a sudden loss of power.
michaelkenward
Mar 26, 2024Guru - Experienced User
abinda wrote:
Tried resetting multiple times and nothing changed. I fully reset the router (MR60) and nothing has fixed the issue
By resetting do you mean the reset "pinhole" in the back?
No luck with the Sync button?
Have you tried moving the MS60 nearer to the MR60?
Is is just one satellite? Or do you have others?
Is it wired to the MR60 or on a WiFi link?
That's not in the usual repertoire. Are you sure it isn't blue? They can be confusing.
abinda
Mar 26, 2024Tutor
Yeah i tried resetting using the pinhole on the back. I tried moving it closer and wiring it into the router but no luck.This is the only satellite i have and it’s just solid white, it does not blink or anything, as soon as the power goes in it becomes solid white.
- abindaMar 26, 2024TutorI also tried updating the firmware on the website by plugging it into my computer. However there was not an option for the satellite and i could only see an option for the router
- FURRYe38Apr 08, 2024Guru - Experienced User
Log into the MS web page and update FW there. You can update the FW directly using the MS web page.
abinda wrote:
I also tried updating the firmware on the website by plugging it into my computer. However there was not an option for the satellite and i could only see an option for the router- abindaApr 08, 2024Tutor
How do I log on the satellite webpage, Im aware you can login into the routers webpage with https://routerlogin.com/. If i succesfully connect to the satellite webpage do i need to be using the routers wifi and also Do i need to connect the satellit to my computer via ethernet to update the firmware?
