abinda
Mar 26, 2024Tutor
Nighthawk MS60 solid white light
My satellite has suddenly stopped working. It was working fine for a while until now. It will not connect to the router and cannot be reset. The light is constantly solid white when plugged in. Tried ...
- Dec 13, 2025
I could not find any solution, I tried many things, but I ended up having to purchase a new one. I believe this was hardware issue instead of a software one. I'm almost certain the satellite bricked after a sudden loss of power.
abinda
Mar 26, 2024Tutor
Yeah i tried resetting using the pinhole on the back. I tried moving it closer and wiring it into the router but no luck.This is the only satellite i have and it’s just solid white, it does not blink or anything, as soon as the power goes in it becomes solid white.
abinda
Mar 26, 2024Tutor
I also tried updating the firmware on the website by plugging it into my computer. However there was not an option for the satellite and i could only see an option for the router
- FURRYe38Apr 08, 2024Guru - Experienced User
Log into the MS web page and update FW there. You can update the FW directly using the MS web page.
abinda wrote:
I also tried updating the firmware on the website by plugging it into my computer. However there was not an option for the satellite and i could only see an option for the router- abindaApr 08, 2024Tutor
How do I log on the satellite webpage, Im aware you can login into the routers webpage with https://routerlogin.com/. If i succesfully connect to the satellite webpage do i need to be using the routers wifi and also Do i need to connect the satellit to my computer via ethernet to update the firmware?
