abinda
Mar 26, 2024Tutor
Nighthawk MS60 solid white light
My satellite has suddenly stopped working. It was working fine for a while until now. It will not connect to the router and cannot be reset. The light is constantly solid white when plugged in. Tried ...
- Dec 13, 2025
I could not find any solution, I tried many things, but I ended up having to purchase a new one. I believe this was hardware issue instead of a software one. I'm almost certain the satellite bricked after a sudden loss of power.
mas1005
Dec 13, 2025Tutor
I have the same problem, but the solution suggested above doesn't work - the satellite that is stuck with the sold white LED shows "disconnected" on the main router webpage so it is not possible to do firmware update that way. Resets (via pin at back), power cycle doesn't change anything. The white LED is solid, comes on as soon as the box is powered up, then nothing else happens, no network connectivity, the ethernet port on the device is dead (no connection).
abinda
Dec 13, 2025Tutor
