abinda
Mar 26, 2024Tutor
Nighthawk MS60 solid white light
My satellite has suddenly stopped working. It was working fine for a while until now. It will not connect to the router and cannot be reset. The light is constantly solid white when plugged in. Tried ...
- Dec 13, 2025
I could not find any solution, I tried many things, but I ended up having to purchase a new one. I believe this was hardware issue instead of a software one. I'm almost certain the satellite bricked after a sudden loss of power.
mas1005
Dec 23, 2025Tutor
Thank you for the reply - yes, I also bought a new (actually refurbished) satellite and added that - now I have the other problem that there is no way to remove the dead-satellite from the system so I have to live with a red / disconnected satellite in the network map and constantly see 4/5 satellites connected rather than 4/4
- FURRYe38Dec 23, 2025Guru - Experienced User
Can try removing the disconnected MS from the MRs web page using a web browser...
