Btrembla2's avatar
Jun 19, 2020
Nighthawk R8500
I have a Nighthawk R8500 and i love it!!! My problem is that i have a garage that is dettached and i can't get a signal to it. I was looking to add the MK62 to my existing R8500 setup. My only question is whether this would work or can someone recommend a better solution?
  • plemans's avatar
    Jun 19, 2020
    The MK62 *might* work but it also might not.
    Problem is the brick and it being an exterior wall. Exterior walls tend to be thicker and have more materials that block wifi.
    Most routers/extenders are all already hitting the FCC's broadcast restrictions so switching to another device doesn't usually add power to the equation.
    If its only 20ft, you might be better off to run an underground ethernet wire and just put an access point in the garage. Your dlink extender might even have access point mode so all it'd cost is the wire and some time to run it.
  • plemans's avatar
    How far away is this detached garage?
    What materials are your exterior walls of your home and on the garage?
    These are important factors as adobe, brick, concrete, plaster lathe, metal siding, foil lined insulation all do great jobs of blocking wifi. It would change how you set stuff up.
    • Btrembla2's avatar
      Btrembla2
      Tutor
      Garage is vinyl siding, house isa mix of very coarse brick from the 70's and vinyl siding.
      Garage is approx. 20 feet away from the house.
      I tried using a DLINK extender from my bedroom where it's the closest point but it sux...i get a few bars and it's slower than molasses running down a tree in the middle of a Canadian winter :)
      I was thinking of trying to connect the MK62 (replace the dlink) in my bedroom then have the satelite in my garage...
      • plemans's avatar
