jfreiberg
Mar 27, 2021Initiate
Nighthawk Router - Mesh Wifi 6 System
I'm not to tech savvy, and I just bought the Mesh WiFi 6 System. Currently, I'm using a router supplied by Spectrum. Should I replace the Spectrum router with the Nighthawk router or can I just con...
Mar 29, 2021Guru - Experienced User
What modem and router is it?
That's the question.
If its a modem/router combo device, the steps are different than if its a seperate modem from the router
jfreiberg
Mar 29, 2021Initiate
It’s the MR60 (Mesh WiFi 6 System). It came with a router and 2 satellites. I ended up disconnecting the router that I have through spectrum and using the new router. It seems to be working great now.
- plemansMar 29, 2021Guru - Experienced User
glad to hear it!
let us know if you have issues
