eb73's avatar
eb73
Nighthawk Satellite Compatibility / System upgrade
Hi,
I have a nighthawk mesh system, approximately 3 yrs old. I've been experiencing signal issues lately and having done modem and exterior inbound cable checks, I think it might be the router and I am content to update.
Will my existing MS80 satellites work with any newer nighthawk mesh systems?
Thanks for your input.
  • plemans's avatar
    No it wont.
    1. what size is your home?
    2. you have the MK80 system? How many satellites?
    3. using a hardwired backhaul? Wireless backhaul?
    4. what modem/gateway is it connected to?
    5. What issue are you having in details? The MK80 system is pretty solid so the better you can describe your issue, the better we can help
    6. what firmware is on the router and satellites?
    • eb73's avatar
      eb73
      Hi,
      Home is 300 sq feet but router is a one end and I am half a flight up at the other end of home.
      I am using MR80 router and 3 MS80 satellites, my desktop (point of frustration) is connected to a satellite via ethernet. This satellite is connected to a satellite midway to the router - i see the chain in the network map on the nighthawk app
      Not sure what you mean by backhaul
      things run great and intermittently there is a slow in service where nothing works - connection is practically nil
      Firmware is all up to date as far as I can tell via app, the modem is an Arris S33
      • FURRYe38's avatar
        That size of home, only really need the MR. Maybe one MS at 30 feet.
        Having 3 MS would be too much.
  • michaelkenward's avatar
    michaelkenward
    What is that newer Nighthawk Mesh system? You don't say. If it is an MK8# system, maybe.
    If not, then plemans is spot on.
    Might be worth a bit more investigation of that.
