kbettich
May 13, 2020Aspirant
Nighthawk Wi-Fi 6 mesh with 2 MR60 routers
I own a large home with 3 floors and I have Ethernet CAT6 wiring from each floor down to my Broadband AT&T router. I wanted a single reliable and strong WiFi SSID through my whole house so I purchase...
araghava
May 15, 2020Star
MR63 is now available at Costco. This is a router MR60 with 2 satellites. You can connect the LAN port on routher to a switch and connect each satellite to a port on the switch.
You can do the same with your existing system by using just the satellite from your 2nd system if you like.
- kbettichMay 15, 2020Aspirant
So let me get that straight: connect MR60 LAN port to a LAN switch port using an Ethernet cable. Connect both MS60 satellites LAN ports to that same switch so they logically sit on the LAN behind the MS60 router
- araghavaMay 15, 2020Star
Correct
- captain69Oct 07, 2020TutorHow do you disable the router and DHCP server, and just pass through your own DHCP services and LAN through the LAN port? The MR 60 insists on being connected to the Internet through the “Internet” port and the ONLY documented way of configuring the thing is by using the Nighthawk app, which has zero manual configuration options. I should’ve just bought another unifi AC AP pro and called it good, but Costco made this seem like a simple Wi-Fi extender. sigh
- liquidgeekNov 23, 2020Tutor
put your mr60 in access point mode. i have a pfsense firewall setup in my home which is my dhcp server, i set up my mesh network into access point mode. the dhcp is passed through the access point without issue. also if your going to do this plug the ethernet cable from your switch into the lan port of the mr60 and not the wan port.
- zee928Feb 04, 2021Aspirant
Have MK63 (MR60 + 2 MS60). MR60 is in AP mode.
Trying to use backhaul feature, but all the examples and comments I see are talking about MR60+2 satelites connected to same switch.
My setup is : ATT/ROUTER -> connected to 3 switches (1 to each LAN on ATT/Router) -> MR60 is behind switch #1 connected via LAN port not WAN, MS60 is behind switch #2, and MS60 is behind switch #3. This way each floor of my house has a 8 or 5 port switch.
Any reason this setup doesnt work?
Thanks,
zee928
- captain69Nov 24, 2020TutorYou cannot put it into AP mode from the app. You HAVE TO use a web browser. PITA! 😡
