MikeBrun
May 21, 2023Follower
Nighthawk Wi-Fi 6 Router and Nighthawk Wi-Fi 6 Mesh System
I have had a Nighthawk Wi-Fi 6 Router for a few years and recently had an issue with it. Tech support solved the issue but recommended I get a mesh system to strengthen the signal throughout my home....
michaelkenward
May 21, 2023Guru - Experienced User
Was that Netgear tech?
Beware any suggestions that you spend more money.
You don lt need Mesh to "strengthen the signal". There are cheaper ways of going that, depending the circumstances.
Mesh is good for a wifi network that is easy to use and has the same SSID and passwords that devices can connected to as you move around without any noticeable pauses as you move from one wifi source the the next. But that needs several sources that work together. You may find that just one inexpensive "extender" will get what you want.
So start with what you want to achieve and not with what someone suggests.
I have a setup a bit like plemans but I have also used simpler and cheaper systems.
