Sprint8
Apr 14, 2022Initiate
Nighthawk Wifi 6 System 2 routers
I have a Nighthawk Mesh Wifi 6 Mesh system with one router and 2 satellites. I wanted to extend the system and the shop sold me another Nighthawk Mesh 6 System (AX1800 MK2) system that included anothe...
- Apr 14, 2022
no it won't act as a satellite. It'll be a separate network.
The guy should have simply sold you more satellites.
The manual goes over how to set it up in access point mode.
Sprint8
Thanks Plemans
How do I set it up as an access point?
I can connect it to the network via and ethernet cable, once thats done will it perform the same way as a satelite (but wired not wireless)?
Apr 14, 2022Guru - Experienced User
