ehaoe
Dec 02, 2021Aspirant
Nighthawk Wifi Mesh System with Xfinity Gateway
I previously had my own modem connected to a Nighthawk Dual-Band WiFi 6 Mesh System (router with one satellite). I recently upgraded to the xFinity Gateway that has a built-in modem and router. I wan...
- Dec 02, 2021
I found an acceptable solution (option 3) here: https://community.netgear.com/t5/Nighthawk-Mesh-System/Nighthawk-AX-1800-MK63/m-p/2158564
Dec 02, 2021Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Netgear has set up a community forum specifically for the NightHawk MESH products. Most of the people who watch that forum are more likely to have experience with NH MESH products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Mesh-System/bd-p/en-home-nighthawk-mesh-system
Thank you.
