ehaoe
Dec 02, 2021Aspirant
Nighthawk Wifi Mesh System with Xfinity Gateway
I previously had my own modem connected to a Nighthawk Dual-Band WiFi 6 Mesh System (router with one satellite). I recently upgraded to the xFinity Gateway that has a built-in modem and router. I wan...
- Dec 02, 2021
I found an acceptable solution (option 3) here: https://community.netgear.com/t5/Nighthawk-Mesh-System/Nighthawk-AX-1800-MK63/m-p/2158564
ehaoe
- FURRYe38Dec 02, 2021Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
