Mtylor
Nov 27, 2021Aspirant
No powered/unresponsive nighthawk ms60
I've had this system for a year now and the only thing I have had issues with is the satellite. Currently, it has no power going to it even after swapping power cords from the main router and trying a...
Nov 27, 2021Guru - Experienced User
Nothing is lighting up on it? not a power led, nothing?
And you tried a different power supply?
Sounds like a hardware failure. Are you still in warranty?
To get a hold of support. Click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process. It'll also show you if you're still in warranty or not.
- MtylorNov 27, 2021AspirantNo lights at all. It came back on after not being plugged up all night but went dark again. How would I use the warranty because I have till DEC 1 and would like a replacement
- FURRYe38Nov 27, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the NightHawk MESH products. Most of the people who watch that forum are more likely to have experience with NH MESH products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Mesh-System/bd-p/en-home-nighthawk-mesh-system
Thank you.
Mtylor wrote:
No lights at all. It came back on after not being plugged up all night but went dark again. How would I use the warranty because I have till DEC 1 and would like a replacement - plemansNov 28, 2021Guru - Experienced User
To get a hold of support for your warranty. Click on "MyNetgear" at the top.
Register an account (or login) and then the device. That'll let you check the warranty status.
From there you can start the support process. Keep in mind that its only free for the first 90 days for when you talk to someone. Usually if it is a hardware failure, they'll refund that fee but ask for that first.
