Atharv
Jan 01, 2023Aspirant
OpenVPN "Server poll timeout" MK63
Hi! I was trying to configure OpenVPN on my router so that I can access my NAS from anywhere. Unfortunately I have tried connecting using Android, IOS and Windows and all fail with the same error. It...
Atharv
Jan 02, 2023Aspirant
Don't have a double nat, already checked that. All my cables are cat 5e or cat 6.
However I did manage to figure out the issue and I think a lot of people will have this now. My ISP is doing a CG-NAT because of which the ports are closed and cannot be opened by me. I figured this out when my routers ip address was different from "what's my ip" on google.
Is there a way to setup a VPN even with a CG-NAT or do I need to get a static IP from my ISP?
Jan 03, 2023Guru - Experienced User
So this would be a double NAT condition. You'll need to ask your ISP for help with this.
