jneskowin's avatar
jneskowin
Follower
Aug 04, 2021
Pin a device to one of the three meshes
Hi, I have a MR60 router in my home. I noticed that my laptop gets assigned to different mesh units though the laptop is startionary at one part of the home. Often it gets assigned to the mesh furthest from it. Is there a way to pin the laptop to a specific mesh that is physically the closest to it? Thanks
1 Reply
  • FURRYe38's avatar
    No. It's up to devices to pick and choose where they connect too.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    Try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
