Anhvhoang
Jan 27, 2024Tutor
Please help MS80 connection issue!!!!
Hello everyone, I've had my MR80/MS80 for 6 months without any problems. However, yesterday, I noticed one of the satellites in my garage continuously switched between orange amber and blue lights. A...
- Jan 27, 2024
Interesting that the User Manual (page 15) shows only two colors:
Usually the first question is, "What Changed?". Could be something as simple as placing some object in the path between router and satellite (garages often are used to "store stuff" and WiFi is sensitive to passing through materials.) Or, the orientation of one of the devices could have been changed.
The units have both been rebooted?
What is the physical distance between router and satellite?
CrimpOn
Jan 28, 2024Guru - Experienced User
The first step would be to restart those devices, either by using a "Restart" command in the relevant application or by cycling the power to the device. (Not "Reset". Simply "Restart".)
Reasoning:
Devices intended to be mobile are usually programmed to scan the WiFi environment almost constantly, looking for a better connection. In WiFi terms, this is called roaming. Mesh WiFi systems were developed specifically to use new IEEE standards which facilitate the hand off of devices from one WiFi node to another. Smartphones, tablets, laptops, etc. almost always have this feature.
Devices that typically remain in one location are often programmed differently. When they have no connection, they scan for a WiFi network that they have been connected to before. When they see one, they attempt to connect. Once connected, they quit looking. Smart plugs, cameras, garage door openers, thermostats, etc. are often programmed this way. If they lose WiFi for any reason, they go back into the search mode until a WiFi signal reappears.
When a device restarts, it begins in that original search mode. This feature sometimes causes a problem when the entire WiFi system is restarted, such as after a power failure. If the router begins transmitting WiFi before the satellites, then sometimes devices will 'stick' to the router.
Anhvhoang
Jan 28, 2024Tutor
Got it thank you for your information. I think i know why this issues happen to me since a week ago i got power outage and after that i think everything is reset but then the issues recently appear. I might need to run a ethernet cable to the Satellite in garage using Backhawk feature so hope all connection are stable.
Thank you
- michaelkenwardJan 28, 2024Guru - Experienced User
The problem with a power cut is that things can go wrong when the power comes back on.
The satellites can start in the "wrong" order.
I have seen this. My layout is designed so that one satellite sits about halfway between the "remote" satellite and the router. To get the best signal, the remote satellite should talk to the "middle" satellite first, but it ends up talking to the router.
The solution is to run off the remote satellite and wait for the router and the one in the middle to get their connection. Then turn on the remote satellite and it usually sees sense and reconnects to the other satellite.
I might need to run a ethernet cable to the Satellite in garage using Backhawk feature so hope all connection are stable.If it is easy, the wired backhaul should be faster and more reliable, but it may depend on the geography of your network.
