WesL01
Oct 28, 2021Aspirant
Port Forwarding a MS60 Satellite
If I port forward a port lets call 44158, to the ip of one of my mesh satellites so it looks somthing like linked below. will this allow everything that conects to that satellite weater its hardwired...
Oct 29, 2021Guru - Experienced User
You don't need to PF a MS.
You only need to PF for a devices that is connected to the MR or MS that needs external WAN side specific port services.
Be sure if you set a PF rule, that you disable uPnP.
