oligarchy
Feb 22, 2023Aspirant
Port Forwarding trouble with Nighthawk MK63/MR60
To preface, my network is setup like this: Fibre Terminal → GS105 Switch → [MR60/MK63] [PC] [TVs] The Firmware is V1.1.7.134_2.0.65 My public IP is static to my knowledge I've been trying for ...
Feb 22, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Is the WAN IP address a ##.##.###.### address or a 192 or 172 or maybe a 10.something IP address?
Be sure uPnP is disabled on the router before setting up any PF configurations.
Be sure that your actively using the port prior to using port checkers.
- oligarchyFeb 23, 2023Aspirant
I'm unsure of the model of the ONT, but I am using a cat6 connection everywhere. The WAN IP address is 100.XX.XX.XXX and the Public is 200.XX.XX.XXX.
