oligarchy
Feb 22, 2023Aspirant
Port Forwarding trouble with Nighthawk MK63/MR60
To preface, my network is setup like this: Fibre Terminal → GS105 Switch → [MR60/MK63] [PC] [TVs] The Firmware is V1.1.7.134_2.0.65 My public IP is static to my knowledge I've been trying for ...
Feb 22, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Is the WAN IP address a ##.##.###.### address or a 192 or 172 or maybe a 10.something IP address?
Be sure uPnP is disabled on the router before setting up any PF configurations.
Be sure that your actively using the port prior to using port checkers.
oligarchy
Feb 23, 2023Aspirant
I'm unsure of the model of the ONT, but I am using a cat6 connection everywhere. The WAN IP address is 100.XX.XX.XXX and the Public is 200.XX.XX.XXX.
