drh841
Sep 08, 2024Aspirant
Preventing circumvention of OpenDNS
Hi Community: I'm trying to follow the suggestions to use the firewall to prevent circumvention of OpenDNS as per other users on the forum and as per documentation https://support.opendns.com/hc/...
Sep 09, 2024Guru - Experienced User
Might ask the guy who wrote that article.
- drh841Sep 09, 2024Aspirant
Well, I tried the first link. I think the problem for my understanding probably came up that "Block services" for DNS didn't really mean block ALL DNS activity, only DNS requests that didn't originate on the router. I rather thought that blocking DNS would simply block it entirely, even the router's attempts to use DNS. I know that sounds weird now, but it certainly isn't clear on the router interface or in the documentation.
At any rate, I think this worked. I blocked services for port 53 and if someone's settings are trying to use a different DNS it just blocks it. ... It also seems to block it if it IS trying to use the OpenDNS servers... Would like that second part to function as well. I'll fiddle around a little more, maybe that's the port forwarding part.
Dave
PS, not sure what you meant about reaching out to "the author of the article." The one I referenced specifically said that that author and its company would not assist further than what they printed as they can't support everyone's router firewalls.
- FURRYe38Sep 09, 2024Guru - Experienced User
Glad something worked for you then.
So I guess take that article with a grain of salt then. Should have some support to a point.
I guess fiddle and find the what works for you. Please post what works if you can.
- michaelkenwardSep 09, 2024Guru - Experienced User
Could be OrbiPhilip but they have not been seen for a while.
