Stalhill
Sep 28, 2022Aspirant
PS5 Remote Play vs Netgear Nighthawk Home Mesh Wifi (MK63)
Hi all, I am looking for advice, and although I note various threads already on PS Remote Play, I couldnt find anything specifically linked to Nighthawk Home mesh, or indeed very much recently posted...
michaelkenward
Sep 28, 2022Guru - Experienced User
Stalhill wrote:
So until a couple of months ago, I really dont recall having any issue with PS5 Remote Play on my iPhone 13 struggling to connect to my PS5, however recently its become a bit of a nightmare and I consistently struggle to connect to my PS5 over WIFI.
Is this the nub of the problem?
PS5 Remote Play cannot connect to wifi from MK63.
Where does the iPhone 13 come into the picture? You are streaming to it?
What about everything else? Can that get on to the MK63?
Stalhill wrote:
Hi all, I am looking for advice, and although I note various threads already on PS Remote Play, I couldnt find anything specifically linked to Nighthawk Home mesh, or indeed very much recently posted (in 2022)
Is this where you looked?
Search - NETGEAR Communities – PS5 Remote Play
Stalhill wrote:
All apps, software, and firmware is up to date.
Only a number can confirm that.
Saying "the latest". may not be by the time people read this. There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
It might also help if you told people what the modem is in front of this router, if there is one. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
Finally, while many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Mesh System - NETGEAR Communities
- StalhillSep 28, 2022Aspirant
Is this the nub of the problem? YES
PS5 Remote Play cannot connect to wifi from MK63. Kind of, My Remote Play app cannot connect to my PS5 via wifi.
Where does the iPhone 13 come into the picture? You are streaming to it? YES, as I say, using the PS Remote Play app on my iPhone
What about everything else? Can that get on to the MK63? YES, that why I've posted specifically about Remote Play, and not the Wifi Mesh in general.
Is this where you looked? YES I did, but nothing about MK63 (or similar) having these issues and most reports were years old.
Saying "the latest". may not be by the time people read this. There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface. I was confirming all devices are up to date as of posting. I'm not aware of any updates that are not showing as available of course.
It might also help if you told people what the modem is in front of this router, if there is one. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back? The Modem is VirginMedia SuperHub3 - wireless is switched off on the SH3, the Home Mesh is doing all the wifi (thats in AP mode).
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting. I'm pretty sure this is an issue between Netgear, my iPhone and obviously finally, it could be the PS5/app. I suspect Netgear as it wouldnt be the first time their firmware upgrades have messed things up and for instance they already have a widely acknowledged issue with Apples Private Relay (BETA) until recently causing a connection issue to the Netgear app directly. Of course it could be the iPhone causing the problem (Private Relay....) or if PS have changed something...Finally, while many questions about routers are generic and could be answered anywhere, some things need specialist knowledge. I don't doubt it, but my first port of call is to see if anyone has also identified this issue, and who is a bit more tech savvy, discovered the solution.
It all feels a little challenging the first response to my first post. Not exactly feeling welcome right now.
- michaelkenwardSep 28, 2022Guru - Experienced User
Which bit of the first message mentions AP mode? Did I miss it?
That is a different kettle of fish.
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
So, you finger Netgear as the cause of a problem created by Apple?
Sadly, "being pretty sure" isn't a lot of diagnostic help. As FURRYe38 says, problems with Apple and Sony, which seem to be the suspects, is down to them.
It all feels a little challenging the first response to my first post. Not exactly feeling welcome right now.Fault finding is down to careful analysis of the symptoms, based on having as much detail as possible. That's why we throw all those boilerplate questions – like firmware version and modem/gateway details – at people who turn up here asking for help.
Your first message managed to leave out a lot of valuable details, like AP mode.
- StalhillSep 28, 2022AspirantNo, I don’t finger Netgear, I say I think it’s a problem ‘between’ them.
Geez, I guess I know where to come in future to learn HOW to be precise enough to ask a technical support question….not so much the right forum for someone to get actual answers though.
My bad for being someone who isn’t that technical. Guess I’ll go and ask my question somewhere else.
