scoggnito
Feb 22, 2021Aspirant
QoS
I have the MR60 Mesh router with 2 MS60 satellites. My issue is with QoS. I have it enabled, but when I select a device in the list to change the priority, it will open up a different device. Eve...
Christian_R
Feb 25, 2021NETGEAR Employee Retired
Hello scoggnito,
Has support been able to follow up on your case? What firmware version is your system currently on?
Christian
scoggnito
Feb 25, 2021Aspirant
Thanks for the response.
I chatted with support, but they provided no real help. Just the same troubleshooting I had already performed.
Firmware is v1.0.6.110
- Christian_RFeb 26, 2021NETGEAR Employee Retired
Hi scoggnito,
May you send me a private message with your email address and case number(s).
Thanks,Christian
- NoobNoobMay 02, 2021Initiate
I'm Having the same issue everytime I click on a specific device it loads another device, i've contacted support but no help from them running Firmware Version V1.0.6.110_2.0.49 on Nighthawk mesh wifi router (MS60)
- Christian_RMay 05, 2021NETGEAR Employee Retired
NoobNoob,
I would recommend reverting to the firmware version below as we pulled firmware v1.0.6.110.
https://kb.netgear.com/000062202/MR60-MS60-Firmware-Version-1-0-6-102
Christian
