scoggnito
Feb 22, 2021Aspirant
QoS
I have the MR60 Mesh router with 2 MS60 satellites. My issue is with QoS. I have it enabled, but when I select a device in the list to change the priority, it will open up a different device. Eve...
scoggnito
Feb 25, 2021Aspirant
Thanks for the response.
I chatted with support, but they provided no real help. Just the same troubleshooting I had already performed.
Firmware is v1.0.6.110
Christian_R
Feb 26, 2021NETGEAR Employee Retired
Hi scoggnito,
May you send me a private message with your email address and case number(s).
Thanks,
Christian
- NoobNoobMay 02, 2021Initiate
I'm Having the same issue everytime I click on a specific device it loads another device, i've contacted support but no help from them running Firmware Version V1.0.6.110_2.0.49 on Nighthawk mesh wifi router (MS60)
- Christian_RMay 05, 2021NETGEAR Employee Retired
NoobNoob,
I would recommend reverting to the firmware version below as we pulled firmware v1.0.6.110.
https://kb.netgear.com/000062202/MR60-MS60-Firmware-Version-1-0-6-102
Christian
- Skyfox88Oct 28, 2021Aspirant
My firmware is V1.0.6.116_2.0.54 and I have the same issue, please help.
