TimHemmelman
Feb 22, 2022Follower
Question about the lan port on a MS60
Can the lan port be used to connect a hardwired device like a computer, hub or switch? Or is it only there for the sake of hardwiring the satellite to the router. In my setup the satellite connects...
Feb 22, 2022Guru - Experienced User
You can connect devices to it.
what device are you connecting?
What firmware is on the satellite and the router?
