linercapr
Apr 28, 2023Follower
Question about the Nighthawk Mesh WiFi 6 System
I am looking at the 2 pack Nighthawk mesh system and was curious how these work in conjunction with a router? Does one of these beacons act as a router? I am building a 4,000 sq ft home and I don't...
michaelkenward
Apr 28, 2023Guru - Experienced User
Any particular Nighthawk mesh system? Something in the MK range?
Depending on which you go for, they come with a router (MRXX) and satellites (MSXX).
I am building a 4,000 sq ft home and I don't believe there are any routers that would cover that kind of space.
So, router plus enough satellites to cover the area?
Try plugging your needs into the filters on the product pages:
NETGEAR'S Mesh WiFi Network Routers + Systems
Then check back here for reports on the things you are considering, but remember that people turn up in this community with problems, not compliments. So look at reviews on Amazon, for example.
