Cbass1122
Jun 09, 2020Aspirant
Rax120 - MK63: want to use the router on MK63 as a satellite or extender
My house is about 4000 sq ft and the fiber modem is outside mounted on the garage with the fiber cables running to the router in the basement, which drives me crazy. Would make this much easier if it ...
Cbass1122
Jun 11, 2020Aspirant
Thank you for your reply. That’s kind of what I was planning on doing, but just the router has to be converted to an access point, right?
Also, I don’t need to directly connect the MK60 router to the RAC120 via Ethernet, right?
I assume the mesh Set up is a better option than getting an extender or two?
Thanks again for the help.
schumaku
Jun 12, 2020Guru - Experienced User
To make an AP system out of thr Nightawk Mesh system, yes.
Of course you do - it's not yet another wireless extender or repeater ...
Seriously - install a bunch of network cables, ideall in a star configuration from the router to each floor and each place where you consider to connect computers, TVs, or wireless access points. Less cost and effort than buying more and more wireless consumer boxes and kits - where none can make wonders. To many of these in your house already...
Sorry if this does sound not very popular. And it's not "compatible" to Netgears consumer business marketing too. Then you migh want to look into Netgear's Insight system...
- Cbass1122Jun 12, 2020AspirantThanks for the info. Are you saying I should use the fiber connections throughout the house instead of adding mesh points or extenders all over the house? If so, the only problem is that I have 56 Hue Lights/LIFX lights and various other smart home devices that need to connect via Wi-Fi.
Also, if I have to connect the MK60 router to the RAX120 router, won’t that added step slow the internet speed a bit? I would love to Declutter and create a system that’s more streamline and simplified.
This wouldn’t be a problem if my router was able to be set up on the main level (2nd Floor). Thanks again for the feedback. I want to make sure I know what to do and that it makes sense before I buy another mesh system.- schumakuJun 13, 2020Guru - Experienced User
Cbass1122 wrote:
Are you saying I should use the fiber connections throughout the house instead of adding mesh points or extenders all over the house? If so, the only problem is that I have 56 Hue Lights/LIFX lights and various other smart home devices that need to connect via Wi-Fi.Not sure what you designate as "fiber connections" in this context. Is there a kind of network wiring in the house where you have access to both ends?
From the performance and reliability view, using wireless is fine for a "last hop" network connectivity say for mobile devices, or the light control is fine. The point is that having two or more wireless hops from the router to the access point (the radio where the clients are connecting to) are adding latency, variable performance, ...
Cbass1122 wrote:
Also, if I have to connect the MK60 router to the RAX120 router, won’t that added step slow the internet speed a bit? I would love to Declutter and create a system that’s more streamline and simplified.You don't want to operate the MR60/MS60 system in router mode, instead in wireless access point mode. Ethernet connections are always faster, more reliable, add less latency than any wireless technology.
Cbass1122 wrote:
This wouldn’t be a problem if my router was able to be set up on the main level (2nd Floor).For the possible wireless coverage this would help a lot, being for the possible coverage from the RAX120, being from the ability to add Mesh extenders, or wireless connected Mesh like the Amplifi.
Best would be having network cables installed to selected, many, or all rooms, operate the router and a switch downstairs (most wife acceptance), and deploy wireless access points in various areas of your house (ideally PoE driven). You can even install small switches in a room where yor multimedia stuff is located, in a home office, ...
- Cbass1122Jun 15, 2020AspirantSorry, the modem is outside of the garage, mounted to the wall. In the utility closet in the basement there are about 6-7 orange Ethernet cables from the modem. One is for the internet and connects to the router. The others are for any room in the house that has an Ethernet/fiber connect in the wall. I refer to them as fiber because that’s what Century Link called them.
Thanks for your help. Although, I’m probably going to have to look up some of the things you said, as I don’t yet have a full grasp on the proper terminology.
Thanks
