BigU2K's avatar
BigU2K
Follower
Jan 25, 2021
RAX200のwifiサテライトとしてMR60及びMS60を接続したい
自宅用にRAX200を購入し、wifi電波が弱い部屋があったため、AX1200(MR60ルーター、MS60サテライト×2)を追加購入しました。
wifiがRAX200とAX1200とで、それぞれ別のwifiとなってしまいます。
同一のwifiのままで2機種を使用したかったのですが、RAX200のwifiサテライトとしてAX1200を設定できますか?
1 Reply
  • schumaku's avatar
    schumaku
    Afraid, my Japanese is not the best.
    The RAX200 is not really a WiFi Mesh router, the MR60/MS60 (Kit designation MK6x) system is an Easy Mesh system which can be operated either in router or wireless access point mode. Neither the MR60 router nor the MR60 satellites can be connected wireless to the RAX200. Access point mode would require a network cable (LAN) connection from a RAX200 LAN port to the MR60 WAN port when I have it right.
    The smarter investment would have been e.g. into an Orbi 6 system - don't know if you would be able to return your purchase for an exchange.for a Netgear Orbi WiFi 6 Mesh System AX6000 (RBK85x) for example.
