jaymz69
Mar 20, 2021Apprentice
HomePod Mini Not working on MR60 Mesh WHEN Satellites are NOT Plugged in
After working with Apple support on this we came to the conclusion that the homepod mini can airplay fine (my Apple TV too) ONLY when none of the satilites are powered on. Works for all the AirPlay f...
- Nov 10, 2021When you upgrade/downgrade, always do it satellite first, router after:
103 beta for MR60 https://ntgr.my.salesforce.com/sfc/p/300000000xsV/a/0y00000056JP/J38PBLjMmRLFiBA.rZ3qMk516lZy0vHSpvBSeMBA_do
103 beta for MS60:
https://ntgr.my.salesforce.com/sfc/p/300000000xsV/a/0y00000056JQ/68c76CRT0ugwEUuOpPyVBJVosFw8z36VQqT3wzdV6RI
According to their support the fix should come in next firmware, in between you can try this.
Christian_R
May 06, 2021NETGEAR Employee Retired
Hello Community,
May you confirm that you're on the firmware version below and let me know if your issue persists.
https://kb.netgear.com/000062202/MR60-MS60-Firmware-Version-1-0-6-102
Christian
bollee23
May 07, 2021Tutor
Hi,
also V1.0.6.110 on router and satelites
- jaymz69May 07, 2021Apprentice
1. This is what I am on for Firmaware when I log in.
2. I also keep trying to turn OFF the security for 'NEATGEAR Armor' but it always times out on me with the error taking longer than 60 seconds.
My Router: Nighthawk MR60 Firmware Version V1.0.6.110_2.0.49
