jaymz69
Mar 20, 2021Apprentice
HomePod Mini Not working on MR60 Mesh WHEN Satellites are NOT Plugged in
After working with Apple support on this we came to the conclusion that the homepod mini can airplay fine (my Apple TV too) ONLY when none of the satilites are powered on. Works for all the AirPlay f...
- Nov 10, 2021When you upgrade/downgrade, always do it satellite first, router after:
103 beta for MR60 https://ntgr.my.salesforce.com/sfc/p/300000000xsV/a/0y00000056JP/J38PBLjMmRLFiBA.rZ3qMk516lZy0vHSpvBSeMBA_do
103 beta for MS60:
https://ntgr.my.salesforce.com/sfc/p/300000000xsV/a/0y00000056JQ/68c76CRT0ugwEUuOpPyVBJVosFw8z36VQqT3wzdV6RI
According to their support the fix should come in next firmware, in between you can try this.
Crt-crt
Aug 25, 2021Tutor
Btw, I confirm there IS a fix. They have a firmware in testing which the customer support agent sent me. I had to agree to an NDA before they could send it. Since I installed it has been WORKING for ages, no more bugs. It fixes it 100%.
I send my details to the moderator in this thread. He said to contact him if you had trouble. He forwarded me to one of their support agents. If you look you will find him in this thread asking for your router details.
