in2ndo's avatar
in2ndo
Apprentice
Jul 22, 2021
Latest MR83 firmware V1.1.6.4_3.1.92 and attached devices not showing in network map
Has anyone updated the MR83 to the new version 1.1.6.4 ?  I'm running iOS app ver. 2.10.5.17  and now the attached devices don't show up under network map.  I see the router and the 2 satellites.  b...
  • in2ndo's avatar
    in2ndo
    Jul 27, 2021
    So just in case anyone runs into the same problem of loosing or not been able to see the attached devices in the network map of iOS or android app.  after updating to V1.1.6.4.
    I re-flashed the MK83 back to V1.1.5.4 and everything is back to normal.  now I can again click on the network map and on the router and each satellite and it shows the list of what is connected to each.   So the problem is V1.1.6.4 .
    Support is suppost to be escalating the issue.
    I tried the iOS app on an iPhone XS an iPhone 8 and also on an android device.  they all the problem with V1.1.6.4.
    Again,  I know I can view this info. on the routers web page. but if I want to be able to keep an eye on the hardware.  this needs to work on app.  specially since is not just one plain old router but 3 pieces of hardware that need to be monitored every once in a while.
